Frustration
Virginia Beach
I recently posted for information about reman calipers. The reason is that during a stop I would have a pulsating in the pedal and a lurching feel to the entire vehicle. Well I replaced the the calipers with remans from the toyota dealership, the pads were still in great shape so I reused them and I had a set of DBA rotors turned. Well after an afternoon putting everything together I took it for a test drive. For the first few stops everything felt great and the car seemed to be moving a lot smoother. But eventually the "lurching" came back but the pedal did not pulsate and on a few occasions the steering wheel would go back and forth. Now I have new/remans calipers all the way around good disc brakes on the front and turned ones on the back. Bled the brakes until I could see new fluid coming out.
What is causing the lurching of the entire vehicle?
My last thought is a bad balance job which I am taking it back to Evans Tire because that is where I purchased the tires and it's free.
Info: The lurching has not always been there. It is something that is fairly recent, around six months now. IIRC it started around the time I got my tires balanced. It was not imediate. Regardless I have new brakes but would like my stopping to be a little smoother.
I searched and only found one thread by bpen but he just swapped pads.
I would go with you on this one and get the tires re balanced, especially since its free.
You may want to read up on adjusting the proportioning valve which controls the pressure to the rear breaks. If it is not right it can lurch you forward to much to pressure on the front not enough in the back.
