frozen doors
Junk
Mod Emeritus
buggerville nj
Anyone else have issues with frozen doors when it’s cold out? I love the cold, but not being able to open up the dang door because it’s frozen shut just sucks. BTW, it was not frozen shut due to snow on it, just the cold!
I have a remote starter, so I can start up the truck without being in it, but just because the inside is warm doesn’t mean I can get in.
Besides takin a whiz on my truck door, anyone have any brilliant thoughts?
Anyone else have this issue or is it limited to the beater edition? :mad:
NJ don't get that cold. It was 4 today, but that is nothing compared to many other places. That's why I want to know.
Moisture ...
Thaws , melts , resolves itself into a dew .. then refreezes :flipoff2:
hmm, what about applying some petroleum jelly to the weather stripping or something like that? You should have plenty around, right? :flipoff2:
My DS rear door was frozen shut last night so I got in the passenger side and pushed it open from the inside. Worked for me :D
Ouch.......or Hmmmmm. But I does sound like a good idea....On the door jambs.
For me the locks were all frozen last night / this morning along with the doors. The grease must have seriously gummed up because it was -25 C (-19 F).
The auto unlock with the alarm did nothing. So all of the locks were half way between lock and unlock. The key helped and then the door was frozen to the weather stripping.
I climbed through the trunk! While the alarm was going off because I was arming / disarming the truck to unlock the doors. That probably didn't look to good to the neighbours.
If you tie a 2in strap to the inside of the door and let it hang outside the door by the handle it will give you good leverage. While you pull the handle with one hand you pull the strap with the other. Assuming of course that you can get it unlocked.
same here, junk. i'm in central nj and had the same issues this morning. my key wouldnt unlock the doors but the remote did. the door seemed stuck at first but a good pull swung it open. the windows were also frozen until the interior warmed up.
junk, what remote start do you have? i went looking today and only saw a viper combo (auto start/alarm) for around $299 installed. or $199 for just the auto start, but then i'll have two remotes, errr.
I went the cheap route (Valet) and have 2 remotes. Was part of the negotiated deal when I bought it. The deal was that the dealer had to replace the crapped out radio, buy me a roofrack and pay for install of a remote start.
yea, there is goop yo can put on the rubber.
But Junk, don't take a whiz out in the cold. Starting from near zero as you are, you gonna go negative if there is any shrinkage... :D
You might want to reconsider using a petroleum based material on the weatherstripping as it might prematurely degrade it and that stuff isn't cheap to replace. I'd try one of the silicon or teflon sprays on it.
Alternatively you could buy Christo's seat warmers but install them in the door panels...
I'm sure Junk's got plent of K-Y jelly around...that might work better :flipoff2: -- it's water soluable though, which could be good...or bad in this case.
I like the idea of the silicon lube...that's the way I'd go.
Silicone spray in the fall on all the door ruber seals. The doors are sticking because of the moisture freezing the seals to the metal, but you already know that. The silicone displaces the moisture. A portable hair drier is the answer for frozen locks. A couple seconds and the locks are dry. Then spray in some lock deicer found at your auto parts and you are set. Same principal as the silicone, it displaces moisture and lubes the lock mech.
Junk, you might want to try replacing or at least cleaning and silicone lubricating your driver's door belt line molding. That's the wiper strip that runs horizontally along the base of the window on the outside and acts as a partial moisture seal. Mine is worn to the point that it does not touch the window anymore so when you lower the window and then raise it again no condensation is wiped off the window. A little hose test showed it is admitting mucho water into the door. I just had my door off to try to fix my regulator and noticed a lot of moisture and condensation inside my door leading me to this conclusion. I imagine that in NJ that moisture and condensation is dripping in when you drive then freezing when you park.
By the way, I only know what it's called because I just ordered one from Dan along with a regulator and rubber window liner ("glass slide"). I plan to have the fastest driver's window west of the pecos so that I spend less time in the morning at the parkade in winter opening my door to put my pass in the machine.
Thanks. This morning I used the BFA (big fat ...) not to be confused with the BFH which is what it will get next time.
BTW, Norcal, :flipoff2: :D
Another cold related question. It appears that my washer nozzles, both front and rear, have frozen. Neither will spit out any fluid and there is plenty of washer fluid in the tank. Any suggestions? I tried poking a pin in the nozzles to free up any ice, but it didn't accomplish anything. Thanks
Ary
cruise4070 said:
Hey Junk, you can try licking the lock with your tongue to warm it up.
I triple dog dare ya! :flipoff2:
Why don't you try that with your tool first knucklehead :flipoff2: :D
Arya - your prob is the crap is frozen in the lines. Get that orange stuff that has de-icer mixed in. Someay I'll route some tubing so I can spurt warm wiper fluid.
Junk said:
Someay I'll route some tubing so I can spurt warm fluid.
Whats that kids like to say ??
"OVERSHARE!!!"
