Front Window Replacement Question
Cincinnati, OH
How difficult is it to replace the right front window? The fsm doesn't seem to say much about it. Maybe a :banana: rating and time estimate would be the most helpful to me.
Huh?
The "Body" chapter should have a whole "front door dis-assembly" section, with glass removal as one of the last few steps.
But really, nothing in the doors is hard to repair/replace. Just follow the steps, and post up if you get stuck.
I guess I'd say one banana, plus another 1/2 for just making sure you're being thoughtful and patient and not breaking things.
What happened to your window??
Curtis
Someone broke my window so they could steal my laptop. Broad daylight, I had my laptop behind my driver seat with my jacket not so obviously placed on top of it. Just trying to decide if I should replace the glass myself.
Oh look...its raining today.
Its a piece of cake. I just had an issue with the track in my door, so I had to take the window out to work on it.
Take the door panel off, remove the square window control module from the bottom left corner (to gain better access to the interior of the door), lower the window track to the height where you can see the bolts in the front and rear access holes, take a 11mm ( i believe) and remove the two bolts holding the window track into the window assembly. (There should be plastic over the door...I just cut the plastic and then recovered it with part of a trashbag and duct tape).
Slide the new window in and screw the two bolts back in and reassemble the door.
Took me all of 5 minutes to remove the window so I could work on the track.
thanks a bunch
There should be plastic over the door...I just cut the plastic and then recovered it with part of a trashbag and duct tape.
That used to be my approach as well. :lol:
Then I learned from folks here that it makes a lot more sense to just carefully peel the existing plastic from the existing gooey sealant, and then press it back on when done.
Cheers,
Curtis
