Front winch bumper
I have an ARB with factory tie downs in place. Never actually needed to be use them for recovery, but if I did I wouldn't be overly concerned.
People rip on the ARB for being thinner and less strong than something like Slee. Depending on the end user, that's not necessarily a bad thing. Also, that top loop has saved the front end of many Cruisers from animal strikes.
Thanks the bio looks like a good optio
Lots of really good bumper out there with real recovery points; Slee, BIO, 4x4Labs, Metaltech... just to name a few. Check out the Vendors area for more options.
I used to have an ARB, now I’m running the tube bumper posted above. Mike, the owner of BIO, is a great guy to work with and can make changes if you wanted anything added.
First, and foremost, position yourself in a safe location so if something goes wrong you’re not in harms way. This applies no matter how cool your recovery gear is.
If your driving a vehicle and trying to pull someone out it is kind of hard to reposition yourself from the driver's seat. I watched this video a few days ago, it was pretty interesting....
Not sure where the idea that they are only for tie down comes from. Toyota calls them out as a tow hook. Yes, you can get ones that are stouter. However, IMHO, these are totally adequate for recovery and it is also MHO that is what they are designed for.
On to the topic at hand. I have an ARB bumper that came on a rig I bought. I do like the look. However, it is not very stout compared to others on the market. It would not be my choice for a wheeling bumper. It is sufficient for overlanding and cruisers that see mostly on-road duty.
Have you ever had your 80 towed? The process involves a flatbed or trailer winching your rig onto the flatbed/trailer with the tow hooks, then they use big tie downs and chains attached to the tow hooks to secure the vehicle. I am sure they are adequate for that use, but these loads are nowhere near the loads experienced in recovering a stuck vehicle. When a rig is stuck in deep snow or mud, wedged into the rocks, or rolled over and stuck I think it is much better to use a legitimate recovery shackle that can hold up to the dynamic shock loads experienced in these situations. I have always been told that you want the weakest link in your 4x4 recovery set up to be the pulling system. So if your winch is a 10,000 pound winch you would want it to stall way before you reached the load limits of your recovery gear ( winch line, shackles, straps, etc ). Here is a great article
Vehicle Recovery | offroadTB.com
And there’s a huge difference between the stamped transit anchors that most vehicles use during shipping and that big old chunk of steel that’s present on the four corners of an 80.
There's pictures floating around lcool.org/forum of these failing, and of the damage caused when they let go. (Did a quick search, but didn't find them)
Failure is probably a fairly rare thing, but then 95% of cruisers never see dirt, and 90% of recoveries are going to be a gentle tug, and tow points see fairly mild loads.
When SHTF they become questionable, and in a high pressure, urgent SHTF scenario, if you don't have the presence of mind to look critically at what you're hooking up to, things can go tits up fast.
Send it lol
That "big old chunk of steel" is bolted to weld nuts in the frame.
One way these have failed is bolts have stripped completely out of weld nuts, and that big old chunk of steel becomes a missile.
Other things that bother me about these is the relatively thin base plate, 1/8 - 3/16 plate.
Also the fact the loop is welded the the mounting plate. I've seen some ordinary looking welds on these
Looking at the picture above the frame horn appears to be where the damage was done, most likely a side pull. The recover point and bolts looks to be intact.
No matter how beefy of a recover point is installed the limiting factor is how it is mounted and how the load gets distributed in multiple planes. Two bolts attaching to the frame is not sufficient in itself. When bumpers like the ARB are installed it strengthens the frame horn by limiting the horn from rotating and also passing some of the load to the opposite side frame rail. Most bumper designs out there do that so I would not call any of them inferior, just some may be able to handle higher loads.
At a certain point the weak link is the recovery gear. The straps, shackles etc. used need to have the proper ratings be in good condition and used properly. Its all a recovery process including equipment and people that requires safety as the primary concern. In my many years on this planet I've seen a lot of stupid stuff done with good equipment.
I just recently acquired an ARB bumper. Anybody know if the @TRAIL TAILOR recovery points require the spacers that come with an ARB for the factory tow points? Unfortunately my bolts have worn out threads so I was only able to attach one factory tow/tie down point using the spacers. Need new hardware but wouldn’t mind getting the trail tailor tow points as well.
And we have no record of the environment these trucks lived in nor the situation in which they failed. Many of of the anchor point replacements also utilize the factory frame-captured nuts.
Watching the cable snapping in the video above was pointless in most of their "tests" because what moron is going to cut a hole in the windshield or run a winch cable over the top of their truck? Also, every one of these we're intended to pull to failure, using a 40,000 lb dozer.
We talk about tow point failure. Anyone can make any part fail if you're a big enough idiot!
How many morons try to.pull people out in reverse?
How many morons back up close and get a run for it to hit the end of the chain or strap?
How many morons hook on to tow at a severe angle?
How many morons try to pull out a vehicle with the winch cable extended from their winch but pulling with the truck and not the winch?
There are things you should and should not do during recoveries. Seeing the worst case scenarios in YouTube videos will help you understand IF you understand what you're looking at.
Agree with the first part of this.
Understanding the limits of every part involved in a recovery whether it is shackle, chain, strap, or recovery point on your vehicle makes for safer recoveries.
True.
I went digging for one example I remembered from the lcool forum. The factory tie downs had been relocated to the rear of the frame. Captive nuts were corroded, and bolt threads damaged on install. The bolts pulled out during an attempted snatched recovery.
Still, begs the question, do you know the condition of integrity of the 25 year old factory tie downs, bolts, and weld nuts you're using for recovery?
What I found interesting from the video is how much damage a synthetic line could still do when it snaps, I have heard people say they are safe when they snap. They might be safer than steel but I wouldn't want to get hit by a snapping synthetic line. And the video also showed how easy it is to cause a line to snap, it just takes one sharp edge to contact under tension. Moral of the story is to be careful doing recovery's, the load forces experienced when winching or yanking with a rig are tremendous and deserve the utmost respect. No 4x4 is worth a life.....
