Front Wheel Drive 80
Ardlethan NSW Australia
G'day every one,
My name is Scott & I live in a small NSW country town called Ardlethan. I'm originaly from the city & have been into & owned Land Cruisers for the past Nine yrs. I'm not real great with these computer things, I prefer to be out makin tracks in me cruiser! Which so happens to lead me to this question! Out bush bashin the other, I did a uni joint in (rear of front tailshaft). I figure no problem, just drop the front tailshaft & drive home in 2WD! I did the deed, climbed in to go but there was no drive in any gear until, I push the centre diff lock button. What gives ? Have I not just made the truck think its front wheels are spinning in the mud and there for the back wheels should move me without difflock? I suspect there is something wrong with the trans case. Does anybody out there have any ideas or suggestions on this ????
Cheers, Gibbo
Completely normal. There's a diff in the transfer case, just like the ones in the axles. If you lose traction on one axle, that output shaft will spin free, especially an early 80 without the viscuous coupler. If you want to move, you have to lock the diff, which you did, and you're set.
Nothing wrong with it, that's the way it's supposed to work.
-Spike
If you go to post for on the FAQ it goes into depth about the diffs.
https://forum.ih8mud.com/showthread.php?t=84888
basically the centre diff will put the power to the end with the least resistance. Which is the one with out the shaft in this case. Same theory as the rear or front diff with out a locker. The tire with the least resistance gets the power. That is why the tire that is in the air spins and the one on the ground doesn't move.
So your centre diff lock just makes it a normal 4wd. With two open diffs(unless you have lockers).
Read the faq.
Yep, won't hurt anything. Track your fuel usage, many have found no advantage to running 2wd, as you're still turning everything. The responsiveness you're feeling is probably just the different feel, but if it's an improvement to you that's all that matters. You'll be doing crazy front wheel burnouts. :D
-Spike
