Front Wheel Bearings real-time help
Calgary, Alberta - Canada
I just removed one side of the front hubs to repack and inspect the wheel bearings after feeling a slop in the wheels. I appreciate your help assessing the condition of the bearings since I have no previous experience doing this. Here is a few obesrvations:
- There was hardly ANY preload. I was able to take off both 54mm nuts by hand !!
- I took the hub/rotor assembly to the bench and before taking the grease seal out, I found a fair amount of play in the inner bearing between the inner and outer races. See this video:
YouTube - Inner Bearing
- I cleaned the outer bearing and found similar amount of play. See it in this video:
YouTube - Outer Bearing
- I could move the drive shaft around and pull it out about 1/2" or so. Is this is normal? See this video:
YouTube - Shaft Slop
- The spindle, races and hub all look fine visually, no wear, scarring or deformation
Are my bearings shot or is it normal for roller-bearings to have that amount of play?
Thanks in advance for your help..
Cheers, :cheers:
You need to remove the seal, pull the bearings out, clean them, then inspect. You cannot tell what is going on with them until they are in your hand. The videos you posted show nothing that can ascertain the condition of your bearings.
The shaft play is fine. You need to remember that they are held in place by the snap ring that you removed to take off the drive flanges.
Edit: After seeing the outer bearing video, that is normal. The rollers will be sandwiched between the inner and outer races, the cage is just there to keep the rollers in place.
Thanks for the link Robert. I just checked, they all look shiny and smooth. No scoring, abnormal wear or discoloration. I think I will reuse them.
How about the slop in the drive shaft, it that normal?
Cheers
I addressed this in my first response. You are fine. The snap ring will hold that in place.
