It's probably going to be impossible to find speakers that are exact fits for the doors.
The front speakers are a weird design with a reversed cone that are really shallow. And the back ones are attached to a plastic thing, so drilling will be necessary.
For the front, I popped the door panel off, took out the old speaker, and then popped off the speaker cover and put the new speaker directly onto the door panel with screws long enough to pierce through the door itself, and then just glued the speaker cover back on. If I could do it again, I would use plastic spacers instead of drilling into the door panel.
The rear speakers I basically popped off the door panel, took out the old speaker, used a saw to cut the hole bigger for the magnet, and then drilled 4 new holes for the speaker. I need to use washers or spacers or something though, because now, the bottom of the windows hit the magnets.
