Front runner rack question
Alabama
Front runner rack on the way.... I took off the rails and sealed holes but my question is..... Is it necessary/ suggested to remove the middle bars that lay flat bolted into the roof?i don't see where it matters but just curious. Seem like it would be more work and look worse after
Not necessary. However if I have a heavy item up top and hit a washboard section of road the rack can make contact with the ribs. Not too bad but first time you may poop yourself when you think a yeti has jumped on top of your truck wanting in. I believe they have different height feet so that may apply as well. I only have one set of longer mounts for front to account for curvature of roof.
Just don't order one of their awnings unless you can verify its in stock or you are extremely patient
Might be nice to remove if you plan on storing anything under the rack. You can store a table under there depending on the thickness.
