Front & Rear Axles
work? yes....but they are very weak ball-claw design in front and coarse spline side gears...
IMO, boat anchors or resto parts only...I wouldn't bother.
72 has the fine spline side gears, 1968/69 thru 1997 are all the same for that....
72 has the weakish coarse spline birfields, 1968/69 thru 1975 all have that...76-78 has the "ok" fine spline birfs, 79-90 has the better fine spline birfs.
1958?-1977 has the coarse pinion, 1978-97 has the fine pinion
cruiser ken said:
63 is likely centered rear diff, you probably don't want that.
I wondered that...couldn't recall if the cutoff was 62 or 63....
I have a 72 with junk axles missing brake components and severly rusted. Just wanted to know if a swap was possible.
Thanks,
Vern
Thanks,
Vern
Do you know if the internals are heavily rusted as well? Problee just need a good goin' thru & rebuild. I'm not sure if all the brakelines are still available from Specter either. So, if you're good at bendin' & flarin' up brakelines & mechanically inclined, keep what you have & starta rebuildin'.
