I have been told that my driveline vibration is a classic case of a bad front pinion bearing (vibrates at 45 mph on the gas and then after letting off the gas the vibration resumes after a second or two under engine braking). But then again, another expert says the problem is all in the driveshaft (the U-joints have been replaced, phase is correct and the shafts balanced) and the front pinion seal is not leaking.
The vibes disappear 100% when the front driveshaft is out.
Now to the question:
The FSM on Pages SA-24 to SA-27 (ON-VEHICLE REPAIR) shows that the bearing can replaced without taking off the differential.
I've searched for pictures of the process and find little if any. Are all the special tools necessary or can the companion flange, oil seal and bearing be taken out and replaced with other tools/pullers? If so, any recommendations?
