front locking hub swap question
Pollock Pines,CA
Hey 80 guys, I have a question. I am getting ready to buy an 80 to have as more of an expedition rig. the question is; has anyone had experience with converting to selectable locking hubs on the fron to try and improve fuel mileage, and did this work for you. what were the improvements and what Pros and cons did you notice. and are there any other mods that improve fuel mileage? (yeah, i know...4bt. that may be in the future)
Also, what kind of over the road mileage are you guys getting. thanks for the input -VETTE
You can't just do the hubs. You have to pull the VC and the diff. from the xfer case and put a spool in.
This will make it a true part time rig.
thanks beno. any experience with this or write-ups?
I did the center diff and hubs. Worked great. Got the parts for it from 4wd systems in Adelaide Australia. Not a hard conversion. Took about a day, cause I go slow and read all the directions three and four times for each step. I'm very pleased with the results, though I can't comment substantively yet on the fuel economy change. I did notice an improvement, but I can't give you a good figure on it.
By just running the hubs with out either the kit Beno is talking about or removing the drive shaft, you will with time destroy the bushing inside the selective hubs. It was not designed to take that type of rotations. I would not reccomend doing this Alkaline747trio to anyone.
It is not the right use of the hub.
I have done 4 part time kits in my trucks. 1997 80 series, 2003 Tacoma, 1996 80 series, and 2007 100 series. 0 fuel mileage increase, but better driving in a daily driver and less wear on front end parts. I would do it again.
Jibberish....and even if there were merit to that, do you realize how little it cost to fully rebuild a hub? Do you realize how many miles and rotations it would take to burn up that bushing? Also, let's just say one of those bushings does fail.....what is going to happen and what is going to be damaged?
OK, Hogwash not, By wearing this ring out, you could trash the end of the spindle, when steel meets steel. there is no grease grooves in the bushing to retain any grease, hopefully you have packed the hub well with grease to help ward off heat.
Also the drive plate maintained a center axis of the birfield that would help to maintain the birf to spindle bushing distance. I have seen where wheel bearing being loose has taken the spindle bushing out. So even a little bit of slop can and will mess with the spindle bushing. Unless you went recently to the 105 style of spindles to help control the birfield.
I do not really see where you are saving your self much in the way of wear. Everything is turning. All the seals are wearing, this allows the grease in the knuckle to mix with the axle when the temps change as well. All your pinion and carrier bearings are turning. You are still wearing the birfs, maybe not enough, but still wearing them none the less. Same as the ring and pinion, you are still wearing them as well as they are turning.
So what is it laziness that stops you from getting under the truck and removeing the front drive shaft to truly prevent the wear and tear on the front axle?
I just do not understand the jibberish.
How am I going to trash the spindle bushing with the end of the birf stub shaft being supported by the Aisin hub? I'm also pretty sure my Aisin hub centers my birf stub shaft in the spindle.
Saving wear? When was it ever mention in this thread to do this to save wear? I said this allows me to safely run a front locker on the street. You do realize we are talking about a front end already designed for full-time use, right? And not having the strain of turning the hub/tire/wheel DOES in fact reduce wear.
Just curious, do you have a front locker, Aisin hubs, or a part-time kit? Have you ever run with locking hubs? Do you have any experience with this? Do you even know what the inside of an Aisin hub looks like or how it works?
:confused:
I'm trying to picture a situation where I would ever need to have my front locker engaged on the street....let alone the trail where I very rarely use it.
PS: Robbie is running Aisin's on his rig....I think he knows how they operate and what they look like.
Why, Yes I a little experence with all this. I had my first experence with locking hubs in the 70's, My first experence with Asain hubs in the 80's and I have been running my 80 series on locking hubs for about 6-7 years. With my front drive shaft removed when I have the center locked. I have rebuilt a few locking hubs of many styles in the 30+ years of wrenching I have been doing. I have had more than my share of front axles apart. I have owned, 80's mini's, 4/runner, fj62, and 80 series.
I do know there is a brass bushing on the inner area of the Asain hub, it is not very thick. I have seen them create problems with locking and unlocking the hub when worn out. So with this worn and allowing the birfield shaft to wobble at speed, it will abnormally wear the spindle bushing as well as wear the inner axle seal sooner than if it was being held solid by the drive plate.
Yes it is design as a full time system. BUT you are using a part time system hub on a full time system. It is not meant or design for this abuse.
But as a experiment, it could be a good one. You can tell us what fails and when.
That is how we learn, through failures. Hope it does not hurt too much, if it fails.
Slow91fj90 and I have both been running a similar setup; unlocked hubs + locked center + DS in place. He has been doing so for almost a year now and recently did a regear--meaning he had the front end opened up--and hasn't had any adverse affects.
Just curious, how does having the hubs locked affect how the birf stub shaft acts within the hub? I'm pretty sure locking the hub doesn't support the birf stub shaft any further, it just connects it to the hub.
I'm assuming you're saying there is a bushing behind this circlip that wears out due to supporting the stub shaft?
Uh, Beno....if my hubs are unlocked the locker is negligible.
I know this. With the front hubs unlocked, there is no power/torque going to the front.
What I am asking is in what situation--really--would you need the front locker locked, center diff locked, front hubs engaged (and if on an e-locked 80, the rear would also be locked)--on the street?
I just can't think of one.
No it is not under that Circlip, but the smaller one that holds the gear that slides on the stub shaft.
It really only takes about 15 min to remove the front drive shaft and then you would not subject a part to abuse it was not designed for.
Good luck.
Uhhh, Alkaline, you are arguing with Robbie, really??? I'd stop while you are already behind! :cheers:
Ha! i did not mean to start a propeller war, but it is nice to get one opinion that it did not change fuel mileage. that was really what I was after. thanks guys
