Yeah i know another locker problem. i searched the threads and have performed the following:
in low range, CDL locked with both axles switched to lock the rear will engage but the front doesn't.
I have did circle turns, S turns, forward and backwards.
the front engaged before I changed gears to 4.88s. I know front locker did engage before because i locked it before i pulled the diffs.
It did take a while for it to engage but did engage. Did not check the front after i put it all back together
figured it worked before should work when i put it back together.
i tried to pull motor but seems to be stuck. i managed to pull it off about 1/4 inch, but did not try anymore because i was on the trail.
Anyone have this problem?
Also is there a aftermarket solution like a cable locker to bypass/ replace the electric actuator?
figured it worked before should work when i put it back together.i tried to pull motor but seems to be stuck. i managed to pull it off about 1/4 inch, but did not try anymore because i was on the trail.
