I need to know where does the plug and sensor from the front locker connect to, as I can’t find a harness to connect it to? Please anyone with an axle swap experience from non locker to locker axles chirp in.
The back I figured it out (I think) from other threads, as it connects to the harness in the left front foot area, gota fab some splices and run some wires as there is no part number on the harness where I can just order it, unless someone can tell me the part numbers for both harnesses, then it will be a str8 axle swap with wire connections, but front I can’t find where to connect it to, so it can communicate with the ecu.
job. I believe I am the only one OCD enough to have done this. Took maybe 2 hours start to finish and about 500.00 for parts.
