front knuckle lube
birfields themselves need a moly grease...molybedendum (spelt wrong, but you get the idea) Comes in a round tub.
I use marine wheel bearing grease on the trunions and other bearing surfaces, but the moly is better suited for the shock-type loading a birfield goes thru.
when you rebuild the knuckle, you hand-pack the bearings and then pack the upper and lower cavity of the area around the trunions....I use a 1" rubber spatula for the process.
The inspection plug is to fill the knuckle....IIRC, it's supposed to be 2/3 full....personally, I don't put nearly that much in mine but instead do a teardown/repack of the front axle once a year.
I found some Molybdenum Disufide grease in a tube, have a needle adapter for my grease gun , put the birf in a vise and shot grease in every cavity, rotating the birf as I went. The needle adapter comes in handy for refilling through the plug, too.
Woody, I like the idea of the spatula...next time, huh.
GL
Ed
So what happens if you inject the knuckle more than 2/3 full? Cause I just did..eek!
So am I screwed or what?
Well, Dan, looks like I've been overfilling mine for years. Doesn't seem to have made a bit of difference! Everything works fine.
Thanks for the reassurance. Man, I need an FSM and a brain, there is so much I want to do to both my rigs...oh yea, another job and a fairy god mother to zap all my debt would be nice too:D
For years (at least 15 or so) I've been packing the birfield and and knuckle with as much grease as I can fit into it. I do this once a year. Once everything is cleaned and ready for the repack, I start with the knuckle bearings. I pack these in place by pushing grease into them just like you would a wheel bearing. You know you have packed them full when you see the grease coming out the other side of the bearings. I then pack the outer circumfrence of the knuckle housing with enough grease so that the center hole is about the size of the birfield. I then pack the birfield and finally install the birfield. If I've done it right, I have to remove a small amount of grease that oozes out when the birf goes in. Once the spindle is on, the knuckle is pretty much 100% full of grease.
The only thing that happens when they're this full is that you will see some grease oozing out from the knuckle wipers when the wheels are turned. I just wipe off this grease after I've cycled the steering a few times.
It takes about 4 lbs of grease to do 2 knuckles and the wheel bearings. I've never had any issues with water getting into the knuckles with this method and I regularly cross water deeper than the knuckles during my spring/summer wheeling.
It might be overkill but it works.
There are also a bunch if things like this that make it easy:
http://cgi.ebay.com/ebaymotors/ws/e...tem=4503736057&category=43993&sspagename=WDVW
http://cgi.ebay.com/ebaymotors/ws/e...tem=4503687907&category=35625&sspagename=WDVW
http://cgi.ebay.com/ebaymotors/ws/e...tem=7934949737&category=42614&sspagename=WDVW
There are several styles but for les than $20 it is WELL worth it. Doen in seconds and no mess. I like the style of the first oen with a grease zert on the post. They work like magic.
E
My thoughts
for what they are worth. I used to really pack the knuckles by using a grease gun into the port on the top. I stopped doing this after I found a lot of diluted moly grease inside the entire differential, when I pulled it to install the air locker. If you pressurize the knuckle cavity it has to go somewhere...
I use the moly grease inside the knuckle, including the knuckle bearings and the birfield.
On the 'outside' of the spindle,(wheel bearings) I use the marine grease. If you read up on lubricants I think you will learn NOT to mix base-types of greases, because that causes the lubricant to fall out of suspension. Moly greases I have found are lithium-based, and the marine grease I use is aluminum-based, and so I do not want them mixing.
I also like the marine grease for the shackles, it tends to not wash out so easily.
my $.02, maybe worth $.015
Less is more is the overwhelming response to this one, even if not echoed within this thread. A few squirts through the plug every 3K or at least when you remember will help keep it at 1/2 to 2/3 full.
CruisinTiger said:
hey let me know when you find that fairy god mother. got some debt she can zap away too
