Front inner bearing inspection/remove
I just pop the seal out, and look at the bearings and race....
You can drive the inner bearing out and pop the seal out with it too...
Good luck!
-Steve
"I just pop the seal out, and look at the bearings and race...."
I removed seal and all that appears visible is the wall of bearing housing so can't seem to really see race or nothing. Looks like if you popped it out would still be hard to see bearings. Am I nuts or is this completely different from outer wheel bearing assembly...? :eek:
You have a metal ring piece that needs to be driven out in order to get the bearing out....was only used for a couple years on the early disc fronts.... when you install the new seal, you will not re-use this piece...
Good luck!
-Steve
If ya need help let me know dude....you can call when ever ya want. I will be trying my best to pop a birf next time we go, So if ya dont get it done by then I'll show ya whats up since you'll be in the 80....
-Al
