front hub question
You mean, use 80 series drive flanges on a mini or 60? In that case, no...wont work. Different size and spline count on the stub shaft IIRC.
i meant using the 60 series hub assembly to an 80 series. the reason im asking is these axles are going under my zuk so no need for full time until hitting the trails. i just want to know if it can be done or has been done.
thanks
Ok, re-looked some stuff up. 60 series and SA Mini hubs will bolt right on (if you have the early shorter stub shafted birfs). IFS hubs work if you swap out the hub gear (Bobby Long has a nice chromo piece).
Later (longer stub shaft) birfs and Longs require some machining to get locking hubs to work just right, but it's not a difficult mod and Bobby's warranty still stands with this machining.
