Ok here are the symptoms.
Slight vibration from 10 to about 25 mph.
There is also a larger more prominent vibration when I let off the acceleration at speed anywhere between 35 and 65 mph. This vibration is very short and strong. When the engine is under load or climbing a hill there is no vibration. It is almost as if when there is pressure on the drive train it keeps it from vibrating and then as power is lifted it vibrates when it has idle pressure put back on it it stops.
Now there is also a squeak or chirp coming from the truck only when it is moving at any speed and only when it is not under power. If it is moving faster than 10 mph and no power on the engine than it chirps or actually kind of sounds like a turkey gobble. This did not start until I degreased the engine and yes I rinsed it very well. I did this about 2 weeks ago. I thought it was one of the pulleys or belts so I made sure I lubricated these.
Guys any ideas?
Guys any ideas?
