Front end spring noise
NaterGator
On Gilligan's Island
Gainesville, FL
Anybody had this happen before?
It's been going on for about a year and it's finally driving me crazy but I can't figure out what is causing it and I can't figure out how to fix it.
When the front suspension articulates gently, the USPS spring makes a fairly high-pitched creaking sound; it's similar to the noise that springs in a window track in a home make. Here is a youtube video of some rice burner with a similar noise, but his is louder and lower pitched (and more frequent)
It's driving me bonkers. I've sprayed silicone wherever I thought possible, I've unloaded and trying reseating the spring, etc. As far as I can tell it is not rubbing against anything and is seated properly in the perch. I can stand hunched over in the wheel well between the tire and the body and lift the truck enough to make it happen, but the noise is very difficult to localize other than it's obviously ringing off the spring. The factory rubber gasket wasn't in the best shape when I did the lift, but the other side was equally bad and it's completely silent.
Looking for tips on a fix, besides earplugs :flipoff2:
Check your bumpstops for a shiny line. I suspect you have them off enough so that they rub against the springs. You could also just look at them and see if they can rub under some conditions. If so, you can adjust them by adding washers in the right places.
Kalawang
