Front End Rumble
Just returned from a 6 month deployment and drove the LX-450 (96) for the first time. I did a front axle service before I left, but am now noticing a rumbling noise right around 65 mph on the highway. If I shift to neutral or take my foot off the gas, it goes away, so shouldn't be engine related.
Should have some time this weekend to look at it and was wondering if anyone had a good idea of where to start. Thanks.
Greetings and welcome home....! THANKS!
Just checking here. I recently had much the same dilemma after conducting a bearing change out. My end result was that the 1st locknut wasn't at the specified torque. 96 LC called for (I think?) preload to be 43 foot pounds then, back-off finger loose and re-torque to 48 inch pounds. Once I found/bought the SST (54mm 1/2 drive socket) and torquesd to spec, my problems were solved. Hope I've helped.
Hyatus :beer:
I had the exact same issue with mine.
Hyatus :beer:
I am going to finally check that nut this weekend. Thanks for the clue. I did have a chance to pull my wheels today and also check my transfer cases. Interesting my front transfer case was totally overfilled with oil. I had a local shop put shocks in and also asked them to check the front wheels. It looks like they greased the knuckles from the top hole and also filled the transfer case.
I am noticing clicking as well, but only when the car is coasting (no throttle applied). Is this the birf death clicking or is this that nut (I hope)
Is the truck lifted?? What else has been done with it?? Miles? We need more info!
Front transfer case?? I assume you mean front differential?
Huh?? You're going to need to explain this more clearly.
Worn birfield clicking is usually first noticed during tight turns...
Tell us more, carefully,
Curtis
The truck is a 1996 LX-450 with 126,000 miles on it. It is completely stock and has not been wheeled. I did a birf repack/bearing replacement last summer before going overseas. The click was present then and the reason I did the repack. The birfs looked fine when I pulled them.
When I returned from deployment, I bought some shocks from Dan but didn't have the time to put them on, so I had a local shop do it for me. I also re-noticed the click and asked them to repack my front wheel bearing, thinking that they might uncover the source of the noise.
After that service, I noticed a deep rumble coming from the front end whenever I would take my foot off the gas on the highway. The stories here have made me paranoid about my birfs failing, so I got a quick chance to get my truck up on a rack after work this week. That's when I discovered the overfilled front transfer case, which I fixed and that has eliminated my deep rumble. The click is still there though.
I hearing the click only when I'm off the gas and rolling to a stop. It doesn't matter if I am in gear or not. I do not hear or feel it if I am pressing the gas pedal. I rolled my wheels by hand up on the rack and could not duplicate the sound. This is what I think it could be:
1. Drive shaft needs to be cleaned and lubed
2. Loose nut from my birf repack
Thoughts?
As a followup, I had two problems:
Broken u-joint and a loose locknut. Drives like a champ AGAIN!
