Front end rebuild gone bad
Wet side of Washington
Ok- so I searched- I slept on it- I am at a loss
I pulled my frontend apart the other day to repack the birfs, change the trunion bearings, wheel bearing and other related parts.
And I installed 100 series pads, I had the rotors turned.
As I was installing the passengers side, caliper when I tightned the bolts, the disc wouldn't turn.
I did a search noted that, the 100 series pads were mentioned to have a tight fit. (So I loosned the caliper bolts a little, everything seemed fine) <<------Bad Idea
Anyway, the other side was fine, everything seemed good.
Went for a road test, and hubs were good. Tightend the bolts on the calipers. Drove a little ways, that hub got super hot. <---DUH
So I loosened the caliper bolts, drove home and tore it back down.
I can't figure it out, I can tighten the Hub nuts to the correct pull on a scale. However when I tighten the caliper bolts the brakepads. won't let the disc turn.
It could be a warped caliper, I guess. (the disc was turned at a shop, they also installed the new races)
Not inpressed with their work. There were still metal filings all over the disc as well as in the left over wheel beraing grease left in the hub. ( there could have been some debris under the race not allowing it to seat)
Currently- I have the whole thing torn back down, it appears that either one of the races wasn't installed all the way.<---maybe perhaps
Or I screwed up when I installed the hub. Assuming that when it stopped that it was all the way on the spindle. Seems odd that I was able to get a good, scale reading but who kows.
Maybe it wasn't pushed over the wheel bearing seal?
The issue appears to be with the bearing/spindle.
Any other ideas, before start reassembling?
When I install 100 series pads on 80's, I usually sand the pads down a little with 100 grit emery cloth. Lay the sheet of emery cloth on a hard, flat surface and running the pad in a figure 8 motion for about 10seconds will remove just enough material for them to slip into the calipers.
The caliper slipped on the disc ok, the "binding" occured when I tightned the bolts on the caliper. Leading me to believe that the hub was not on the spindle all the way. (now at the time I was thinking of finishing up the job and going fishing)
The only way I can see that happening is, either the inner seal was catching on the spindle or perhaps the races were not set correctly.
The inner seal has no sign of damage, so I assume it was the races.
Still not sold on that completly. (hoping for someone to come up with something I may have missed)
try torquing the bearings down to the required spec. to seat the bearings, then back off the bolt a quarter to half turn you should be able to hand turn the rotor...the fish scale to me is over rated...just my 2 cents...I know some guys live and die by the scale.
Did you take the shims out for the 100 series pads? I removed my shims to be able to get the 100 series pads in mine.
Ok- so despite the fact that I have a FSM, and claim to have read it before starting the project, and the fact that I had 3 tabs of nuckle rebuild threads up while I was doing the project.
I screwed up, when I installed the calipers loaded. So I am starting over on that part at least.
I currently am having to sand one of the pads. The outer fits, the inner is a bit too wide.
Will report back sooon
