So, a newbie decides to put in some new front u-joints. The result...VIBRATION. its a 1996 model with 90k miles. I used the Neapco Brute Force joints. I took all of the flange bolts loose, took out the drive shaft, took the drive shaft apart into 2 pieces, and changed the joints. I didn't mark the location, so, when I put it back together, it vibrated at 70 mph or higher. Today, I took the shaft out again and re aligned the shaft based on some previous yellow dashes. To re align the shaft, I had to rotate the front wheels to match. The vibration got better..but not fixed. The first time I took it out, I didn't move the truck so I figured if it fit back in, it would be good. What is the next step?? The drive shaft has 2 factory weights on it. Any help would be great!!!
