front drive
Okay today i was taking the dog to the lake and the front stopped working and i had to pull off to the side, and the only way i could get the truck to go is in low gear. when i got my cruiser home i checked the front drive line and it just spins freely. what have i done wrong and how do i fix. thanks!
if it works ok with the transfer case in low range, then i would suspect a stripped front drive plate. (the end cover plate that you can see when you remove the wheel center cap)
The stub shaft of the axle strips out in the hub plate and the power takes the path of least resistance - to the stripped side
but would the front drive line sin freely sitting in park
Did you shift Tranfer case back to High? If you did that unlocks the CDL and is why your front drive shaft spins. As Moj exlpained CDL auto locks when Transfer case Lo is selected and both drive shafts are locked together.
