You've pulled the panel and poked around?Can we get an update. My driver door will not close easily. Same situation as above. All possible obvious obstructions are not an issue.
Y’all just wanted to up date this. I am in the process of reconditioning my FJ80 and I never did fix this door issue. Don’t like slamming the door so I tried to fix. I had used all kinds of lubes on the latch and nothing worked. Then degreased it with brake cleaner and it worked better but still required slamming. The taken a screw driver and activating the latch I compared it to the other four doors. All the other doors activated and latched without much force but the drivers latch required a lot of force. As it would see by slamming door. So the problem is in the latch. Note I drilled out so I had more adjustment in the jam strike and the door was aligned and weather stripping removed. As previous poster said the internal spring can become misaligned. Seeing this door sees most use that is probably the problem. Can by new or used latches onlineCan we get an update. My driver door will not close easily. Same situation as above. All possible obvious obstructions are not an issue. I’m now focused on the latching mechanism
