Front Differential
I'm onboard with U-joints too.
The only FR diff I saw 'go bad' was my own - because I bent an axle shell.
Aside from running one dry, I don't remember anyone here who just mysteriously had a diff go. Hard use / hard abuse that guys own up to is it.
If you don't have them, you need hooknose pliers for the snap lock/rings.
And a grease gun. Only put a single pump or 2 in the splined slider zerk on the rear shaft - when it moves, stop -. That's enough in it.
You could just hit all the joints 1 at a time with a grease gun now & see if the noise changes, that would tell you if / which joint needs attention now.
x2. Forgot the grease gun. Grab the same grease you intend to use in your wheel bearings. That way, when you run out of grease in the tub, in the middle of your bearing/seal job, you won't have to clean up, drive your wife's minivan to NAPA and buy more. ;)
Realized I did a crap job explaining.
If you grease 1 u-joint at a time & take a spin around the block after each joint greased, then the one where the noise stops needs changing now. Or the very worst, you greased all 4 joints & it's not those.
There is a pretty significant clunk when I put it into gear as well as when I step on the gas and again when I let off the gas.
On the early rigs, this is often the birf/drive plate splines.
Yeah, get a 14" arbor press. Let me know when you do. I want to come over and borrow it.
I used my hydraulic press, but without a doubt an arbor press is the superior choice. The hydraulic press has no 'feel'.
As for the vise, I doubt you're going to fit the correct tool and a socket in there in order to press on the sides of the ears correctly. But maybe if you have a really large vise.
Here's an example of the sort of tool I'm talking about (on the left, from this page):
I welded a tool up out of flat stock. You could probably use a bottle jack and the vehicle frame in place of a press.
Definitely superior to vise and socket.
I just don't replace U-joints enough to justify the effort or expense. My bench vise takes up a full square foot on the corner of my bench. One of my top ten investments.
Go to the "Clubhouses" section at the top of this thread and post a request for local help. You're in Durango, CO and CO is full of LC's.
Someone will offer to help or talk you through it.
Not sure what shop you took it to that would tell you that unless all they know are Chevy, Ford, Dodge.
A local club will be priceless. Join and be a part of the movement.
Welcome!
So I took your advice and went to another mechanic. They came highly recommended as a source for LC and 4x4 in general. Just heard back and they said the ujoints are intact and that it's the front diff and possibly the rear diff and transfer case depending on how long the issue has been in place.
Obviously not what I was hoping to hear. Now with 2 separate diagnostics (I didn't tell the 2nd about the first), I guess that's the issue.
Now I have to decide on where to go from here.
Have you greased the damn u-joints?
What reputable shop just canned your diffs & t-case?
We want a name. Hell, I want the name.
I did grease the joints and the cluck was still there. Not sure what to do. I trust you guys as you are a wealth of knowledge with LC and I agree with your diagnosis but 2 shops telling me the same thing freaks me out. Bought it for 3750 2 weeks ago. Not sure if putting the money into makes sense or not. Already threw on new wheels and tires and the Al's Lining is on the way here as we type.
Wouldn't be the first time someone bought an 80 that was missing the birfs.........
So now I'm looking online for front carrier assemblies. Anyone out there have suggestions for site/companies I should be using?
Sooo....what shop?
1 good hr of Slee's shop time would be my solution if I lived in CO.
Diffs are robust, provided they're at least slinging gear oil.
Paging @sleeoffroad
Golden, CO - seems right from shipping labels.
Lord, Christo has a lot of my $$$ but all spent well.
I have to agree with Tools R Us. All 80 series have driveline slop and clunk more than most vehicles, In the early years, 91-92 there is no viscous coupler that would absorb some of the slop. The driveline clunk happens more with light acceleration and letting off the accelerator right at the same time the transmission shifts. The consensus to the cause is the combined tolerances/wear of all the components within the driveline including drive flanges, diffs, u-joints, driveshaft and transfer case. Properly lubing everything will help but you should get used to the clunk and learn to live with it.
I don't think either shop you have taken your LC to has the kind of experience necessary to properly diagnose your problem/condition. Muffler and Brake shops generally don't hire top level mechanics. I would find someone here on MUD local to you that can test drive and give you an experienced opinion.
... that it's the front diff and possibly the rear diff and transfer case depending on how long the issue has been in place.
Those parts are historically solid, have seen a couple of front diff problems from not changing fluid, but rare. The most common clunk points are the drive plate/birf splines and if not greased often drive shaft splines. Depending on how much, clunk is normal on the early non VC rigs.
There IS a POSSIBILITY of a shelled front ring and pinion IF the PO did the pulling in reverse thing. However, if that was the case, it would sound like ball bearings in a blender when rolling.
