Front Diff Empty..
Jefferson
Not sure how long this has been going on but it seems my front diff is either empty or dang close. I could hear the gears in there engaging today (metal on metal w/o lubrication). I drove the truck home immediately and started tearing it apart. There is about 2 inches of rotational play in the front wheels each way before the gears engage. I'm not sure this is even that bad but you's are the experts so I figured I'd post up.
Experience? Suggestions?
Were you loosing your diff fluid out through the nuckle via the oil seal?
Buck Buchanan
Not that i'm aware of. The knuckles are clean, not gooey.
Well, you'll want to figure out where the oil went then- or the problem will re-occour.
Fill it back up and check it over the next couple of days. You might do a fill (wait a week) drain, fill cycle to check for metal shavings in the fluid.
What do you mean when you say you started "tearing into it"? Tearing into what exactly?
Did you drain the fluid and measure how much came out?
Seriously. Be methodical and don't panic. 2 inches of play at the wheel is totally normal-in fact it's low. Pull the diff fill-stick in your finger. If you feel oil, you're good. If no oil, then pull the diff drain. If no big metal flakes, it's fine. Refill with gear oil and keep an eye on it. If there is lots of metal (a beard of metal dust is normal) then the diff needs to come out for a rebuild.
What do the knuckles look like? Gooy?
If there was no oil in the diff, I doubt you could go more than 2 miles without a major problem and very loud noises with broken parts and a disabled vehicle.
Sorry my first post was somewhat vague and missing some crucial info to put this all together.
When I pulled the drain plug there was <1qt in the diff. Way below spec = empty.
I tore into the hubs because I had some wobble from the bearings too. I retorqued the junk and now the PS is tight again, but the DS still has some wobble. I'm going to have to do a bearing job soon, but that's another story and one I have done before.
My post was made in a hurry and it seems I mixed up and added some info that was irrelevant. Oops. It's been a long time since I've been on the board as much as I have been recently. Thank goodness for college graduation. I'll try harder to be clear in the future.
