Front diff carnage and questions
colorado river AZ
Well here's the damage to the diff after last weekend's situation. I pulled suspected drivers brif/axle-all good there. Then i pulled passenger side-splines and birf good there too...oh no i thought.
Ends up, i have one chipped tooth on the ring gear(half a tooth) and the spiders are gone. I have elected to run the ring gear as is for the winter as i can't swing 5.29's with xmas and bdays on the way in my family. The pinion is perfect as are bearings and carrier. The spider debris is responsible for the chipped ring gear. Mesh feels great. Backlash is in spec.
My question is: are the rear spider gears in open diffs the same as the front gears? ARB's web site states the spline count and diameter are the same.. if this is possible, i will swap the rear spider gears to the front, and run an Aussie in the rear. Ez fix really as i takes no time to slap these axle assy's together...anyone want to confirm this?
It went :{ chick chick (reverse) wwwhhaaaaaaaa______whhaa___whaaaaPINGPING whaaannnnnnnnnnnn. click(key off)
otherwise-wot assult on reverse with a hop and a skip combined with heavy 38" tires.
My fz runs particularly well. I knew better. My attitude is directly connected to my right foot at times. It often ends up in my mouth or upside someones ass. When its not doing that, it is wearing out or breaking all of my vehicles. Kinda like that stoner flick "idle hands"..
Yeah, reverse plus skinny pedal seems to break stuff in these.
Sorry, forgot you posted this at first. Major bummer.
Just went and looked at my spare diffs. the side and spider gears are not the same front to rear, different sizes. Sorry.
You might want to look closely at the pinion, for damage. R & P damage in reverse from WOT or heavy pulls can be explained if you look closely at the gear teeth on the ring gear. Notice that one side of the tooth has a "slope" to it and the other side is straight, providing a square surface to the mating pinion. The straight surface meshes and has power applied to it in the forward direction. The sloped side gets the stress in reverse. Under high stress - in reverse, (such as WOT or pulling a stuck vehicle) it is possible for the R & P to slip a tooth, causing damage (usually breaking the top of the tooth where it's mass is the smallest), since the meshing surfaces are not square to each other. Those who understand this can see why reverse is generally treated with more caution for extreme circumstances. And this is just the R & P - birfs have their own worries as do other parts of the drive train.
gears
Dont expect r&p to last very long. The rear spider gears are different. We actually have some good used R&P and spiders in stock. I'd really suggest replacing them.
