front DBC proportioning question
Shippensburg PA
Website
www.iluvrocks.com
greetings!
so my 74 Fj40 is coming along real nice, and one of the fairly recent things I've done is swap FJ60 knuckles/discs/asin hubs onto my original front axle.
I've retained what I believe to be (cause you never know...) the 74 MC and booster which I think are in good shape.
GREAT conversion, but I now need to add a proportioning valve on the rear OEM brakes.
My question is this:
my 40 stops good, but obviously most of the force is going to the rear (rear will lock up way before you get the front to) and it takes some large effort to push the brake pedal enough to stop it. More so than it did with 4 drums.
I'm thinking this is because the rears are trying to do the work... inefficiently... so it takes a lot of pedal pressure. :confused:
If I get the proportioning valve in and set up right, will the pedal force needed to stop reduce? (due to the front discs actually doing the work they should)
I figured some of you have already been through this and could tell me...
Smart dude here!
Before you buy a prop valve & plumb it in, remove the residual valve in the rear (cant remember if my old '73 drum brake mstr. had one). You know where it's at right? If you don't have one in there already, I guess you only other option is to add the prop valve. Here's what the residual valve looks like:
Hmmm, I'm at the same point in my swap and I thought I read that you need to remove the residual valve from wherever the disc brakes were. So wouldn't you remove it from the front not the rear? The rear drums will still need it in place right?
the system is always going to have a hard time feeling like it was designed to be that way since it wasnt. With the caliper size yuo currently have, getting a close to stock feeling pedal is going to require a 7/8" bore master cylinder, which is what is stock on FJ40's and FJ60s with discs. Brake pedal effort is all about the ratio of bore diameters.
sooo....
the proportioning valve won't help at all with pedal feel?
or it will help, but will never feel *oem* until I go with a later master cylinder? (later MC is bigger bore or smaller bore? I'm confused about that as well)
if the latter is the case, anyone have an opinion on a *best* MC to get? (year/model)
and my understanding of the residual valve is that it keps the drum brake shoes from backing off too far from the drums. You remove it from the front of the MC with a DB conversion so that your calipers don't *lock* onto the discs after the first pressing of the pedal. I *think* you need them for the rear unless your doing a DB conversion on the rear as well...
