Front bumper build
North Carolina
Got tired of not having a bumper this past weekend decided to build one
Make sure you paint some teeth on that....just because.
@97lx450guy what thickness steel are you running on the main panel ? I'm not trying to armchair QB you, just a thought. Out towards the corners might be a weak area if you don't extend some gusseting out that way. The lip across the top will help a lot, but lower down may be a bit vulnerable. I've seen a couple of bumpers crumple from corner hits. In extreme cases such as smacking a rock or good sized deer they can wreck a tire and have to be pulled back straight before the rig can safely run down the road. It looks like you have enough material that you could come in 2-3 inches from the outside edge, make a vertical cut, then fold the panel back and weld it. That would definitely strengthen it up. Is that a 130 Hobart Handler ?
damn you guys play rough on here sometimes...the bumper looks way better than what you had before and for the record you don't have to grind the rust off, i didn't and my rear bumper turned out okay...well better than what i had before anyway.
97lx450guy, don't let the haters get in your head. you needed a bumper and you weren't about to spend 2k on one so you built one. that's the cruiserhead spirit if there ever was one. good job man, you built it for functionality and function it will!
Finally, a rational thinker has come to chime in.
This was the simplest, durable, affordable option I could come up with. I could build a complex bumper. But I like things simple and functional. I wasn't even going
Yeah I'm still working on it. Not done. It's a 175. 3/16 all the way around
Meh, guess I'm the only one still running a 110v unit. With 3/16 you've got plenty to work with.
Funny story when I got the welder I was trying to replace my 110 and I showed up and was expecting a 110. Happy with the 220 but I had to make some modifications to my house so that I could reach projects lol. 110 would have made it simple to run a drop cord and make it easy. The 220 handles the load better. I miss my 110
I'm running a clarkeweld en130, welds 3/16 all day long. run whatever you got (proudly) as long as it gets the job done
