What I mean by brakeless is this.
It seems that most of the braking force is being applied to the rear disc brakes. I changed the rear and front brake pads yesterday. The rear needed it but the front had plenty of pad left. The brake situation has been like this since I owned the truck. I thought a change would help.
So you're saying that you are changing out rear pads more often than front? That's a clear indicator that the rear is seeing more force than the front, which can introduce dangerous oversteer conditions in emergency braking.
Could it be the LSPV? I thought it might be but even under a load in the back it is still rear favoring.
I think you misunderstand the way the LSPV works.
The Load Sensing Proportioning Valve works by opening up more, the more load you have. The less load you have, the more it closes and restricts flow.
So "under a load in the back" it would open even more and be even
more rear favoring, not less.
Here's what you do.
- Remove or strap down everything in the vehicle. You should have about the normal load you would carry, but be sure everything is secure.
- Travel to a gravel parking lot or road. You want somewhere with lots of clearance and where you can test braking safely.
- Disable ABS by pulling the ABS fuse.
- Get up to decent speed, and hit the brakes hard. Your goal is to lock up all four tires. (This is why step 1 is important!)
- Look at the skid marks and identify which tires are locking up first (a helper who is outside the vehicle watching will help).
- If the rears are locking up before the fronts, then adjust your LSPV up to reduce the amount of pressure to the rear. This thread may help with adjusting it.
- Repeat until you are comfortable with the braking force.
- Don't forget to reinstall the ABS fuse.
- Travel home, and post up your results here. Include pics!
Keep in mind that you want your fronts to lock up quite a bit before your rears do. The reason for this is that if your rears lock up before your fronts, it will introduce oversteer which is extremely dangerous. If the fronts lock up before the rear, it can introduce understeer which isn't a
good thing, but much more easily controlled than oversteer is.
Keep in mind that in this simple test you will not be introducing a lot of the variables that can make oversteer worse, such as going around a corner or swerving hard while braking. Those will greatly amplify the vehicles tendancy to oversteer, so even if it's impossible for the rear brakes to lock up before the front in a straight line it's possible to cause that in other circumstances.
I've gone into detail on oversteer vs understeer in several other threads. You can read that here:
https://forum.ih8mud.com/80-series-tech/330949-bypass-lspv.html#post4946056
