front brake lines
i did the mini truck disc brake conversion with the 1992 4runner calipers a few months back......i am now realizing i did not keep the small hardline section that goes to the caliper then the soft line....so i have only the 10mm x1 female threaded hole in the caliper to connect my soft line to. Will this be possible? I would like to run some braided lines but it seems that they all have the looped ends. any ideas? thanks!
another thought? do you have to run hard lines at all? could you run braided throughout? My only thought why you can't is because the braided lines are rubber inside and it swells.
By "looped ends", do you mean Banjo fittings?
Ed
