Front Brake Lines for SOA
lengths will vary depending on the setup (low soa v lifted soa, standard flex v eztreme flex, etc). if you use the search function, you'll find the napa number, or you can double stock lines.
so the napa 22" lines for a standard SOA (stock springs) and 2" over shacles would probably work?
bandy rooster said:
with a 4 inch lift i'd prob use the long napa line:
# 22-1/2" long frame-to-axle brake hose for SOA - NAPA 38009
# front axle outer hoses (skips backing plate) - NAPA 38881 (longer) or 38878 (shorter)
i'm going SOA instead of the skycrappers. Ditchin those POS springs for sure! I am gonna use the Napa 38878 for the calipers.
