Front axle snap ring not on
Maine
Went to tighten up my front passenger side wheel bearing today, and when I pulled off the plastic wheel center cap, both the metal grease cup cover and the axle snap ring fell right out!:eek: After reading something in the manual, it seems that in and out movement of the axle is normal, because it tells you to put the bolt in the end and pull the axle out to put on the snap ring. However with the drive flange off, I can also move the end of the axle up and down a bit. Here is a movie to show it: untitled.wmv - 0.56MB Is either of these movements normal? How bad would it be to be driving around without that snap ring on the end of the axle? (since I have no clue how long it has been like that) I have only had the car for a month or so, and am fixing all the PO stuff.
Yes. With the flange off the axle shaft will move up and down some because the inside diameter of the spindle is bigger that the diameter of the axle shaft. The flange is what centers the axle shaft and prevents up and down movement.
Kind of odd that your snap ring was off. Make sure the shaft is pulled out enough that the snap ring seats into the groove on the axle shaft. If it doesn't seem be engaging enough the stay on securely, you may have bent the ring some taking it off. Compress a little or get a new one.
:beer:
Rookie2
Reguarding snap rings...
If you look closely at the ring, one side is perfectly flat and the other usually has a very slight convex shape, or put another way, the edges of the ring slope away. This is a result from the stamping or manufactuting of the ring.
When installing the ring, put the flat edge in and convex edge out, and be sure it snaps on 100%. If it is placed on the other way it "could" appear to be snapped on and not be 100% seated...thus it could come off.
Also, when installing this snap ring, wedge something fairly long in the hole in the axle end. This way, if (when) the snap ring goes flying, it will be caught instead of flying off to wherever parts go when you can't find them.
Good suggestion, I actually did this by leaving a brass drift in the hole just for that purpose, and to hold the axle out instead of using the bolt. The ring is definitely seated good on there now.
