Front Axle Service question
Austin, Texas
I picked up a 93 FZJ80 a couple weeks ago, and the previous owner had the 'front end service' completed (which I don't doubt - the wiper seals looked new), but now it's puking gear oil out, and getting all over the tire. It's leaking pretty good, and I have to put 500 miles on this coming weekend, so I'd like to resolve this quickly, but also correctly.
I'm assuming that whoever did the front end service just used some cheap seals from the local parts store, and not quality ones from either Toyota or Marlin, which is why they're already leaking.
I intend to go in this week & replace the inner axle seals with Marlin's, but was wondering what other parts I should order. Once the wiper seals get wet from the grease & oil leaking out, they're shot & need replaced, correct? What other seals or gaskets in the knuckle assembly should I order & replace while I'm at it?
Looking at the knuckle service 'kits' available from various vendors online, the trunnion bearings look to be about the only part I may not need - is that a fair assumption?
Thanks,
-Mark
You can get the OEM kit from CruiserDan @ american toyota. If it was done recently, you might not need the bearings which are the expensive parts in the kit, the rest of them are fairly cheap, might as well replace them. Make sure you get enough grease for repacking both birf and bearings.
My first check would be the 4 nuts that hold the steering arm on. If they come loose the axle will be off center to the seal and leak.
Well, I dug into it last night, and this is what I found:
Wheel bearings were pretty much completely washed out by the gear oil:
And the culprit:
Going to order up some seals this morning, hopefully have them here tomorrow. What a mess.
The driver side axle is long and heavy, it is tricky to push it in without stressing the inner seal. I just finished mine, and hopefully the seal is still in one piece.
I was noticing that when I pulled it out too - though looking inside the housing, just behind the seal a few inches, there appeared to be a sort of 'guide' to help align it?
I'd hate to ruin the new seals jabbing this sucker back in, that's for sure.
It definitely helps to have a set of extra hands when putting the axles back in. For the cost of a couple of beers and some pizza I'm sure you could find a volunteer.
The 'guide' is the key when you push it in. Had to kind of use it as leverage to push the splines all the way in. No sure I did it correctly. I keep my fingers across.
Get two seals just in case, you will pay more for shipping than for a seal itself, and put down some moly grease around the seal before you inserting the alxe. Good luck,
Well, I pulled a brain fart & forgot to order the wheel seals behind the inner wheel bearing. I had to pull those in order to properly clean out the hubs of all the old grease, so I can repack the bearings.
Hopefully I can get them locally tomorrow, and then start getting this all back together. Hopefully I won't ruin parts on reassembly.
