Front Axle Service prep
Why are you going to rebuild your calipers?
Because they're sticky and need some R&R. I want to overhaul the brake system since it's been ignored. The boots on my rear caliper are torn, etc.
Why are you a smelly pirate hooker? :flipoff2:
They work on the diffs; drain and fill, and on the 93-97 transfer case; drain and fill. That price was from several years ago so you'll probably pay more today. The washers are p/n 90430-18023.
The above information was found by doing Advanced Search, 80-Section, posts only, Keywords=magnetic allen diff*
-B-
Just got mine from Dan. The price is about the same. Here are the parts number:
Drain Plug: 90341-18021
Fill Plug: 90341-18016
Just on a side note, the magnet on the hex drain plug is much smaller than the stock diff drain plug. At the second thought, I put the stock diff drain plug back. Though, I did replace both plugs for the transfer case as well as the fill plug for the differential.
-B-
Great, cheers :)
Thanks also WXM
