Front axle rebuild
Chapin, South Carolina
I'm hearing clicking from the birfields when in 4 low, I'm assuming just doing a rebuild isn't going to fix this. I must replace the birfields correct? I have read where some guys just swap sides, is it worth the risk of that not working?
Is there evidence of the axle seals leaking? If not, you might start off by checking your grease level in the knuckles and fill as needed (sometimes this stops the clicking, birfs are lacking grease). If you do need a complete knuckle rebuild, swapping sides worked for me.
Clicking may be a low grease level condition, or birfs worn out condition. If the seals are not leaking in the knuckle (diff oil mixes with birf grease, diluting it), then you have options.
My experience was clicking AND leaking. I swapped sides and changed all seals and bearings (Cruiser Outfitters), leaking stopped but clicking came back in about 100 miles. Then I had to install new birfs and inner seal (cheap insurance). There is no easy way to tell if swapping will work or not. The second time, installing just new birfs, was a lot faster and easier than the first time rebuild, 1/3 the time.
One thing I did learn, when you remove the shaft and birf, the birf was very easy to move, flopped back and forth with no effort. When I installed the new ones, they where very stiff. This being my first time working on it, I am thinking the "easy floppiness" of the old birf would be an indication of wear.
Also on the grease level, there is a square bolt you can remove, inspect, and add grease. But while doing the rebuild work you have to remove the ABS sensor (12mm hex bolt). The hole for the sensor is 3-4 times the size of the square inspection bolt. So now I am thinking that would be an easier hole to use for inspection/refill? Experts would know.
Thanks for all the input, I'm going to buy some moly grease today and check that first! Question though, what is 3/4 full?? I'm ignorant to this as I have only owned this 80 since February of this year. I'm fairly mechanical and read about using a zip tie to guage it...
I think as someone else stated....make sure you aren't leaking any diff fluid out through the inner axle seals. How does the birf joint/brakes look from underneath? If its wet/oily looking then your inner axle seals are likely leaking diff fluid into the joint.
If you are just adding grease through the port, (I used a bakers cake decorating bag from Target) - I'd plan to add 8-12 oz.....as a guess. I think I put in roughly 18-20 oz in each joint when I rebuilt mine IIRC. Others can chime in...
I too wish they would say add XX oz of grease instead of saying 3/4 full!
The birf ball will easily take 20 oz. of grease, probably more to be 3/4 full.
You can check the level with a zip tie (cable tie).
