Front Axle rebuild?
my front left caliper/brakes were complete gone so i replaced it but now see oil/grease coming out from inside the wheel (front left) flying out on to the tires (as i drive).
i first thought it was the brake caliper bleeder not being tightened enough but it was.. so this leads me to think it's the front axle? does this sound to be a common problem? how bad do you think the damage could be?
i don't hear any noises, i just see a lot of grease/oil coming out... any recommendation on what to order or am looking at?
how hard is the do it yourself fix? how much more work is it from changing the front braking system?
thanks for any help/guidance
At the top of this 80-series section there's a thread stuck, called "FAQ for 80/LX450...". In there you'll find a section on maintenance, and a link in there to front axle/birfield rebuild. If you use the search function on this site there are a lot of other threads about this job, with pics and hints and techniques. With that info and the parts & tools noted, and a little skill, it's a weekend job.
Have a look at the other thread going about front axle seals, same job.
its def not a 5 bannana job... Basically taking stuff out, cleaning and putting back in, or replacing...
Just take your time and dont forget any steps on the put back together part of the job haha
If it's bad enough to be throwing grease/oil on the tire you shouldn't be driving it anymore. Check that the 4 nuts on the bottom of the steering knuckle are still there, when two of mine came out I lost a LOT of grease onto the tire in about 1/4 mile.
Check out Ebay for your KOYO front wheel bearings as well. They are cheaper than toyota. I just got a set for my rebuilt project as well.
CDan's prices are not much over the prices I paid for bearings at Autozone. Knowing you have every seal and bearing and part you will need is priceless. Go with cDan.
koyo bearings are what i got off of dan. if they are cheaper on ebay then I see no problem with buying them there. but id be suprised if they were cheaper than his mud price.
There was some debate here about Koyo vs. Timken. I checked with my supplier, Timken is considered the better bearing in industry, and the supplier had better luck with them at their customers. Not enough difference in price or quality for me to really worry about, but I wouldn't search out Koyo if Timken is available. I posted the Timken part numbers long ago, might search for it.
FYI, my factory rear wheel bearings bear the legend "Koyo High Capacity". No idea if there's any difference but it made me feel special.
DougM
I guess the big advantage of Autozone was they had them in stock when I started the project. When I had the wheel bearings cleaned up I made the decision to reuse or replace, knowing I could buy in town.
i have a loose (12-6 oclock grab while on jacks and get motion test) front passenger side on my 1994 -80 w about 174k miles ... short on time, can i just
a)- 'tighten' something
b)- have to do the full FAQ defined steps of pull wheel to axel etc and clean and put back/replace
c)- if have to do full pull check and re assemble... should i just pay my local guy to do it?
or is it really just a do it in one day task?
DougM
I think its a nice way of saying, "that treadmill ain't gonna walk itself" :flipoff2:
I'm going to plug Marlin Crawler too.
You might as well order the heavy duty inner axle seals from him (slee also sells 'em). Marlin can also sell you everything you need for a front axle job for pennies more than C-dan can sell them for.
My front wheel bearings were Timken I have been told they were from the factory.
I would have liked to go with the marlin inner seals, they look super beefy. The Toyota ones looks pretty weak, but I suppose if everything in the front end is perfect they should work fine.
I didn't notice if anyone mentioned to replace the 8 lower knuckle studs with the new design. I wish I would have done this but I did my axle job a month before the marlin's were available and about a month before the latest "check yer nuts" thread was started.
I have little bit of an amber-clear oily substance that is dripping from my drivers side lower knuckle studs. I'm not sure if it is the valvoline synthetic moly grease separating out or what. The knuckle/arm do not have a visible gap, but I need to get a wrench on them and see if they are tight. I had a nightmare the other night that my knuckle studs failed on the freeway. :rolleyes:
So get some replacement studs so you don't have to worry about that too.
