Front Axle Question
Rustbelt Wisconsin
I'm thinking about making a narrowed down FJ80 Landcruiser solid front axle housing for use in a mini truck/4runner. It looks like they are 63.5 inches wide, compared to 55-1/2 inches for the mini front. I'd like to end up with a housing 60" wide.
I'm wondering if the ends on the housing are the same on the Landcruiser and the mini, so that the outer knuckle will swap? -- Matt
This is a question better asked in the Hardcore section as folks here don't narrow axles. Have you considered installing the front and rear axles to maintain the same width? In addition to the added width and stability you'd get the full float rear axle housing if you install a '94+ axle (some '93 are SF).
If I understand your question the knuckle axle housing are different from the mini trucks most notably in the sheer size. The 80 birfs and parts are much larger than mini truck parts.
Thanks for the reply. I am just learning my way around this board.I'll need to go over to the Hardcore section because I need to know more about the FJ80 front axle.
You suggested using a matching rear axle. IIRC the Landcruiser rears have an offset differential. I was thinking I'd probably end up taking 2-1/2 inches out of a T100 axle to bring it down from 66" to 63-1/2". It could then be made into a full floater with a kit from Front Range Off Road Fabrication , which requires custom length axles anyway.
The "Shop Kulture" blog
