Front Axle Q - Round spring thing...
Minnesota
I'm in the middle of doing a front axle rebuild (new inner axle seals, new trunnion bearings, and rotors/pads) and I realized that I lost the little round circular spring thing behind the inner bearing seal (back of the rotor). I must have tossed it out w/o realizing it. Also, I noticed a similar smaller spring ring located behind the inner axle seal has a little kink in it. This being my first rebuild and not seeing these parts in the FSM or replacement springs in the kit, I'm wondering do I need these? If so, part numbers? Lastly, I'm installing the Marlin Crawler heavy duty inner axle seals from Slee - 87% larger, does anyone know if these little spring things will/should work? -Thanks, Weston
If you're talking about the spring in the inner axle seals, then you want to make *DANG* sure it didn't end up down inside your axle. If it did end up inside, that metal is not going to do any good in there.
A picture would be worth 1000 words.
Thanks, I'm back on track. I didn't realize it's part of the seal and yes, now that I pull back the new seals I see the slinky thing. No worries, the one I lost was from the seal on the back of the rotor, so it's not inside the axle. Much appreciated.
In regards to the Marlin seals Doc says they are the shizznit. I would have used them for sure but I finished my rebuild about 2 weeks before they were advertised.
I would definitely consider using them especially if your axle shaft had any wear marks from rubbing against the old inner axle seal like mine had.
I don't look forward to doing this again so hopefully mine will hold up for another 58K miles. I will definitely look into taking the parts to a parts washer in the future. That is the biggest PITA IMHO.
