Hello
I have stuffed longfield 30 spline in my hj61 front axle made fully bulletproof
except my ring and pinion gear
the problem is the drive on the wrong side?
I looked a little on the ring and pinion gear I have and can see it puts pressure on the small tapered bearing
'm on and turn the entire differential housing 180 degrees?
but it is centert?
but will make the draw on the right side of the ring gear and put pressure on the large bearing on the pinion?
the problem here would then be that it must run backwards to move forward by
Does anyone know if any of the other Toyota transfers run opposite to each other
I think that will solve the problem with the front axle
thank you in advance
I'm not so good at American then used translate
I come from denmark
but it is centert?
I come from denmark
