This is the question.I used Landtank method, 45, finger tight, then 45. The fish scale shows it is within spec around 7lb. The factory manual call for another check after the locking nut is on. But after the lock nut on, it is off, like 16 or so to move the hub. I have used Landtank method before with no problem without fish scale measuring preload. The thing is before lock nut it is just right before 7lb, how low can you go so that with lock nut it is within spec. Something is wrong with the manual. Any idea on this?
