The other day I helped a friend pull a tree stump from his yard. A couple of times while removing the stump I spun all four tires on the pavement (low range, diffs locked, tranny in reverse). This was not a burn out, but one or two revolutions before I got off the skinny pedal. All of the pulls were steady and slow; no hopping or snapping of the tow strap & chain.
Now, I have a growling sound under power coming from the front axle, as well as a slight grinding noise that is proportional to my speed. I removed the front DS and the growling noise was not present, but the slight grinding noise was, which leads me to believe this is an issue in the front axle.
I recently installed Nitro 4.88's; all the bearings and seals in the front diff are new OEM.
No slop in diff
Recent front axle service history:
New wheel bearings/races, rotors, calipers, pads
PS spindle bushing replaced
Birf job done approximately 5K ago
Front diff spins freely, no binding, no clunking
Any thoughts?
No slop in diff
Any thoughts?
