front axle noise
Ancho, NM
Hey, my first post on the 80's forum:clap:
Well my issue is, when turning there is a plunk noise, and it sounds like axle tube. It rarely happens, mainly at slow speed turning, like in a parking lot.............What parts do I need and how much will they cost:wrench::beer::steer: Thanks
I am not sure what you mean when you say "sounds like axle tube."
-B-
It sounds like you will need to service the front axle (aka "do the birfs.")
The procedure is well documented in the 80-Series FAQ. This documentation includes step-by-step, supplies, tools, and parts. If you do the job yourself, including replacing both birfields with new OEM parts from Cruiserdan, you will be looking at ~$1,500. Add another $1,000 to have a mechanic do the job.
-B-
How often does it make the noise? If it's once per turn it's most likely something loose, bushing bad, loose bushing bolt, knuckle/wheel bearing or nuts loose, etc. If it's constant popping while turning it most likely a birf going bad, worn out.
If it is clicking while making a hard turn at low speeds then you need to service the birfs. A strait service without replacing the birfs will run @ 5-600 IIRC + beer and pizza for your helpers.
If you need to replace the birfs the price increases drastically. Cdan is your friend on this one.
