Front Axle Job - tools
Charlotte, NC
Just took delivery of a factory service manual for my LC. I'm just about ready to start tearing into the front axles now. I have read through some posts that have been very informative on this BB. The FSM referred to some tools, seal pullers etc? I have the hub socket and preload scale already, and have a good assortment of hand and air tools. What else do I need?
If all goes smoothly with the front I may do the rear wheel bearings while at it.
Thanks, jt:wrench:
Seal puller will make things go easier...You already have the hub socket and the scale.
Other things I can think off the top of my head besides the seal puller are a torque wrench and a brass drift or hammer to get the cone washers to pop.
For the rear you'll either want to buy, make, or borrow the rear socket tool (SST)...It will make things MUCH easier :)
Did you go through the front axle service rebuild FAQ?
https://forum.ih8mud.com/80-series-tech/78276-front-axle-rebuild-faq.html
Thanks for your replies guys! Yes, I read through the birf project FAQ a while back. Probably need to read it again before staring the job.
I plan to incorporate brake job into this also. The front brakes are easy. I do have an issue with the handbrake; the inside lever is loose and just flops around. I'm sure the linkage etc. is probably seized up at the back?! Saw a recent post on this.
Scottm, I'm in NW Indiana, not too far from Holland. Problem is that my schedule is crazy; kids, work, business. I'll have to work at this a little at a time. Need to get everything completed in time for winter.
I was planning to do some cosmetic stuff with bumpers and running boards; maybe just replace the boards or slee.
jt
Buy the seal/race installer from harbor freight. This tool will make your life so much easier, trust me I just got done rebuilding my front axle. Use tapered side of tool to install races and use flat side of it to install seals, I learned the hard way which side to use to install seals this tool will save you a couple 4 letter word in the end. Also a word about the brakes. They are not easy, 80's series land cruisers are notoriously hard to bleed, I am having one hell of a time trying to get the air out of my brake system now, I may have to take it to the dealer to get it bleed because of the abs acctuator, search spongy brakes here on mud. Other than that front axle job is not hard just messy and time consuming, buy like 6 cans of brake cleaner and 6 rolers of shop towels.
If you ever come through Denver I've got a set of running boards off my '97 LX sitting in the garage for you :hillbilly:
Good luck on the front axle service. You are planning it right if you need new rotors/pad to be doing that now. Just plan accordingly time wise.
And x2 on the mess and need for brake cleaner, shop towells, etc. A couple cheap throw away oil pans to catch the goo coming out is a good idea too. I purchased some cheapy plastic tupperware tubs and some Simple Green cleaner to soak bearings etc. in that were not being replaced.
You do not need a seal installer...just a big arsh socket, think I use a 36mm to drive it in (that is the axle seals)...cannot recall. But if you've got big sockets you can get it done.
Just did a full brake job a few months ago and fixed the parking brake too. FYI, my parking brake was in VERY bad rusty, crappy shape. But I made due with it as I did not want to wait on parts. So, if the parts are cheap, just get new ones and a lot of anti-seize on them...plus, set the brake often to keep it working. But if the parking brake stuff is spendy, you can most likely salvage it all and make it work. You will however, need a vise.
Also...I use zero SSTs to do my work...I do have the hub socket, but that's it.
Have not done my rears yet however...
AND....shameless plug, if you need new running boards...I've got a set for sale...go check em out.
Lastly...and this is important. If the hubs are all packed with old grease and goo, SERIOUSLY take it to a DIY highpressure car wash and clean the hell of of them. I spent more time cleaning crazy, dirty, greasy parts than doing work...went through like $90 in brake cleaner and got totally high too!
Yeah, sounds good. I will get a set of the bearing/race installers. I've been saving a couple of 20% off HF coupons just for this.:D
Brake-wise, I have bled the them about every 2 years without issues. They are difficult; not in my experience. Other than that I have replaced f/r pads a couple of times and rear rotors once. Front rotors will be done 'while I'm in there' on the birf job.
On the handbrake problem I'll just tear it apart and go from there.
Btw, 152k on the clock and still 180# compression across all 6 cylinders.:steer:
I go to O'Hare maybe 4 times every month, usually at odd hours. I usually take the bus out of Michigan City, unless it's a rush drive or midnight. I agree on the crazy, I'm working two careers and raising kids, it's nuts.
My rear handbrake never worked, always meant to tend to that. Bedliner is your best bet for rusty running boards and trailer hitch.
What a mess!!!
Made some progress on the job over the weekend. Started with the left front Saturday and got most of the right side disassebled Sunday. :wrench::wrench:
Had difficulty with the brake left caliper bolts and right tie rod end. Left side grease was runny and just about poured out soon as I loosened the bolts. Right side grease more solid but had some 'burnt' orange color in the spindle. Hopefully I got to it in time!? Both sides had adequeate grease. Both tie rods are done for; broke the left abs sensor. It probably needed to be replaced anyway since the boot was already torn and the sensor full of muck.
Most of the parts are soaking in diesel right now. I'll post some pics soon.
jt
