Oh, man, I'm wishing that I'd done a dry run (pre-grease pack) install on my axles.
This is a mini-to-40 knuckle conversion, and I had to grind the axle housing to get clearance for the mini birfs. I tried to keep the clearance to a minimum, but I'm afraid that I did not consider the wiggling that I'd need to do to seat the axle in the side gear (I've never done this before).
Anyhoo, I'm doing the short side first (looked easiest) and trying to seat it and I cant get it to engage in the side gear. I can feel it rubbing on the end of the axle when I turn the diff yoke, but it feels like I don't have enough play in the fit between birfield and housing to tilt the inner axle around - it's stopping just short of the seal surface.
So, How much space should have I left when I ground the housing? The tech pages say about 1/16th, but I just ground until they slipped in.
Any ideas? I though that I might try loosening my trunion caps in case the preload deformed the housing. If that don't work, I guess I'm looking at unpacking and regrinding . . . ugh. I was thinking about playing doctor, and laying down a layer of heavy saran wrap over the exposed parts, then cutting a little hole around where I will be grinding - but that might be silly. . .
Any ideas would be appreciated . . .
thanks
thanks
