Front axle brake shield
AR
I'm not exactly sure what this piece is called. I've seen it called different names in the different threads I've searched. I'll attach a picture to better explain.
My question is, how does it attach and is it necessary. I can't completely make out which way it is shown on the exploded diagram. It is shown one way in this Romer's thread here:
Front Axle Rebuild - For FAQ
And show another way in the Jonsey video. Yet another video I've watched shows it eliminated. The only way mine wants to fit is as shown in Romer's thread.
I finally got my axles in correctly, and I'm trying to button it up. This is standing in my way now. Any help would be appreciated.
Realized my problem. Somewhat embarrassed to admit it, but I'll do it to help someone else down the road. I somehow mixed up the knuckle housings and put them on the wrong sides. I'm surprised everything bolted up fine and I didn't realize sooner. So learn from my mistakes kids.
Your pic shows it installed backwards/inside-out. Also, it goes between the spindle and the knuckle, not outside the spindle like you have it situated in the pic.
It is installed properly in Romer's thread:
far0024-jpg.55913
Also, the shield is not necessary for proper function of the axle, but It should help keep mud/junk off your rotors. You can run an axle without them.
***EDIT*** Don't be embarassed - at least you figured it out!
Everything went back together fine. Just a small setback. All of the diagram I looked at showed the shield going on after the spindle, so that's how I did it. I don't recall how it came off, but all seemed well when I got it back together.
