Front AHC lower shock bushings
UAE
Hi just wondering a you able to replace the lower shocks bushings only can you buy them separately?
If your able to remove the bushing while it's on the truck then no bleeding, if you take the shock out and use a press, then yes.
Yes it's the same part for your 2001 LX. There are other rubber cushions stacked on the shock that you may consider replacing, but they would require removal of the shock and thus a system bleed.
