Friggin' Zener Diode....
North GA
Third brake light not working; apparently this tiny circuit could be the culprit. No Radio Shacks to be had to try and pick up the correct part.
Anyone else solved this riddle??
Thanks
What zener are you talking about? Where in the EWD are you looking at?
cheers,
george.
Best I can tell from reading posts on the issue its the dark one to the right of the lighter colored......
Are you sure it's a zener and not just a plain diode? The device on the left is a resistor and appears to be 150 ohms based on the colours.
My 3rd brake light is fine so I've never had to open it up, so don't know what the configuration is - i.e. how many of the Red LEDs are in series, where the resistor goes, the diode/zener, etc...
So, how about some more photos (from the back side as well since it appears like a 1 layer board, i.e. traces only on the backside of the board).
If it is a Zener (??) then they have a specific voltage rating so you can't just put 'any' Zener in there...
cheers,
george.
Well, searching found this -> The 36th Lock: DIY Landcruiser Third Brake Light Fix: $0.69
So, apparently a 5.1V zener, if the article is correct. No idea of how it is wired on the board though. I guess you could pick one up and see if it fixes your problem.
A 1W 5.1V zener should fit in that location. Unfortunately unless you have a local electronics part store nearby, it'll cost you more in shipping than the cost of the zener.
cheers,
george.
Cost to repair is still cheaper with shipping than buying a new 3rd light. I think I bought five of them but can't find any of them now.
Glad to read that you got it working. At least it confirms what the fix is. Thanks for posting the outcome back onto this thread.
cheers,
george.
I've got very little experience with zeners, mostly just recognizing they're not like regular diodes. George or anyone who knows more, given people do have problems with these, is there an upgrade possible? Like maybe a 2 watt rated one?
I presume they just burnout due to living a high brake use frequency urban lifestyle?
Or maybe they're on the trail all the time, with a somewhat similar high brake use frequency wilderness lifestyle?:p
A zener breaks down at a well defined voltage (when reverse biased) - that break down voltage is the zener voltage.
And yes, it likely blew due to heat and prolonged use of the brakes. A higher power rating would mean a physically larger device (to dissipate the heat). So a 2W would last longer than a 1W.
It's more than likely being used to somewhat regulate the voltage going to the LEDs. If we knew how many of the Red LEDs are in series (I presume they are wired as a series/parallel combination) we could calculate the dissipation in the Zener based on the 150 ohm resistor in the top picture. From that we'd know if 1W is fine or close to the edge...
cheers,
george.
