Fresh air/recirculate switch indicator
Missouri
I have been working on my heating and cooling system. See this thread
Front heater not hot-what else to check
My fresh air/recirculate switch/button/indicator works but the light always shows fresh air mode. Any ideas on what to check on this. I would like for it to show the status correctly.
Nothing on this yet. I was leaning toward just replacing the switch. Is there a way to test it? It is doing its part to send the correct message to the servo motor, just not illuminating correctly.
If it's really motivating the damper motor, the switch is bad. There are a pair of contacts in it, one to switch the light and one to energize the motor.
This is from the L/C manual, and the LX has a different control unit, but it may be helpful:
Connector "A" is the big white one on the left. (right as you look at the rear of the unit)
Thanks again Malleus. Your help has been very valuable. I hope you saw my updated post on my front heat issues you had been assisting with. I will test and source a switch if it turns out to be bad. Also I thought the LX and the cruiser had the same controls, as long as the cruiser had the auto climate controls. But I certainly don' know that for sure.
de Nada.
I did.
Could be, I never checked. I know my L/C models have a switch on the rear of the C/C unit for "Man/Auto". The LX450 version has a different face; I don't know about the internal stuff. I never broke one open to compare it.
