As promised here are pics of the freeze plug repair. This is the plug on the engine block, there is also one above it on the head. I removed the heater and the tranny cover. Did a thorough flush and cleaned out the plug hole. Also had to loosen the gas tank to get the tranny cover off, so went ahead and took out the seats and sanded and primed the interior. Going Rhino soon...Funny how these things happen once you get started!!!
After getting the cover off, cut a couple of lines up the firewall, bent it out of the way and hammered in the freeze plug with some silicon sealant using a socket, but it continued to weep. Then used some radiator sealant (Bar's I think) in the fluid and resnugged with the socket and an aluminum block. It is snug with no leaking / weeping. The culprit was a malaligned thermostat that jammed closed and would not open, causing overheating. Replaced the thermostat and the 2 (TWO) gaskets. Make sure to tighten down both sides slowly and at intervals so as not to crack the forged aluminum housing. The engine also had an incorrect prior freeze plug - SAE1 15/16 instead of the Toyota 50mm.
