Freeze 12
I assume you guys evac'd the system, correct?
I'll bet they didn't.
Look again at post #17, for example. He still had some r12 in the system, and just quickly changed the fittings (losing a little r12) and started dumping stuff in.
You are of course correct that if the system has been empty and open then it should be vacuumed down and the drier replaced.
You're really thinkin' this through, aren't ya? :D
Don't blame ya,
Curtis
I didn't vacuum it down, but as I stated before the radiator place that also does ac service had worked on my truck and it went in full of r-12 and came out bone dry makes me think it was vacuumed for me. (long story here that I won't go into)
No I didn't replace the drier either, but again this is my $1500 beater that I drive around. This buggy got me through a tough financial time to better times and I didn't have the cash to throw at it back then. But yet I still drive it and love it.
I think if you want a cheap fix as I did it works great, it blows cold and I have had nothing but good luck.
If you want a higher cost fix convert it, depends what your long term goal is. I have been pleasantly surprised with the success I have had with it. For me it was a perfect fix. But I also am looking at a rusty cruiser that honestly as a daily driver up here on the salt crusted roads was a disposable truck. This spring it will be toast, I did all the tricks to keep the frame solid but buying it from someone who didn't take care of it frame wise made it impossible to stop the rust from inside the frame.
John
Guys be careful what you recommend, it is illegal:eek: (EPA Regulations) to recharge any R-12 system with any chemical other than R-12, WITHOUT A COMPLETE RETROFIT PROCEDURE. This procedure includes the use of special fitting for each refrigerant and labeling for each refrigerant. It is ILLEGAL to blend any refrigerant into a R-12 system without properly retrofitting the system. Some A/C component/freon manufactures are less than honest with claims as to what can and can not be done with refrigerants. Check the EPA web site for information.
Many refrigerants will "work" even propane! If you value the system and want to keep the vehicle long term do some research on what you put in it. Freeze 12 will work, but being R-134 based it has some unadvertised issues. Most driers made before '93 are not compatible with R-134, the desiccant bag can breakdown releasing the desiccant (sand) into the system with predictable results. The o-rings in early vehicles aren't compatible with R-134.
My dire predictions of doom and gloom may not happen to you, but why risk it? The o-ring kit is only what $10. the drier is less than $30. If your going to that effort, it's only a flush and replace that 15 year old oil with modern synthetic away from doing a R-134 retrofit, that will net a "proper" system that most any shop will work on?:D
All very good points EPA website basically only states that the R12 must be fully evac'd and contained. Question though on the drier If none pre 93 are compatable with either Freeze12 or 134 than either retrofit would be an issue. (a 92 drier = $66 from CDan)
Issues that I'm playing with:
1. Find some cheap R12, charge it up and see what's going on. If a sloooow leak. Then run with it.
2. Evac the remainder R12, throw some R134 o-rings in, and fill with Freeze 12. Cheapest of the bunch and other didn't even go through all these steps, most consistant issue is finding a shop to recover it in the future.
3. Do the exact same thing but with R134 from which I've gleemed from 3 forumns isn't as cold as either of the above. But is more of a standard
Main thing here is my rig isn't a spring chicken and it's a push to say it's going to be in the fam for 3 more years. (97 or newer on the wishlist) so in the end it will be more of a "quick fix"? Don't know yet
Hey maybe I'll be the guinea pig for the East Valley!
Look for more local info, around these parts 80F is a nice day to drive with the windows down!:D Just about any freon will work at 80F, add 30F+ and see how it performs.:eek:
I wouldn't run it, it's mostly R-134 and performs about the same, so why not just convert to R-134 and have a pure system? Most/all local shops will not work on a system that has been charged with freeze 12. They are required to recover all freon, each type of freon must have dedicated $$$ equipment. The R-142b carrier leaks at a higher rate than the R-134, so if you have a leak it's impossible to know if the ratio is correct. This makes any recovered freeze 12 waste, can't be recovered and reused. Also makes correctly topping off the system difficult or impossible, it must be dumped and recharged.
IMHO maximum A/C performance is needed in our local environment. In your system R-12 will perform the best. If your willing to take the slight performance hit just convert to R-134, it will perform about the same as freeze 12 and you will be able to get the system professionally repaired if needed.
A local supplier forum for more research;
http://www.autoacforum.com/
I gotta go with bro on this one. I worked on Jap stuff for many years as he has. I've dealt with it real-time in shops where an "oops" will bite my ass. I have been bitten.
Freeze-12 was effective in about 80% of cars. The rest developed a sludge that is almost impossible to clean out. The sludge requires replacement of most of the system. Do you want to be the 20%? 134A conversion is successful and easy, why screw with success?
...Main thing here is my rig isn't a spring chicken and it's a push to say it's going to be in the fam for 3 more years. (97 or newer on the wishlist) so in the end it will be more of a "quick fix"?... Don't know yet (a 92 drier = $66 from CDan)
Call BAP Import Parts, the last one I bought (for a '96) was ~$10. Probably not the same quality as a genuine Dan unit, but better than a 15 year old one and plenty good for 3 year use?
Call BAP Import Parts, the last one I bought was ~$10. Probably not the same quality as a genuine Dan unit, but better than a 15 year old one and plenty good for 3 year use?
:cheers:
I was under the impression that changing a system from R-12 to R-134a required changing the oil in the compressor as well.
yep.
Just spoke with an AC guys here in PHX that was recommended and he said to stay away from the R134a because it would be a lot less efficient and leak through an older system a lot fatser...
Looks like R12 for me.
yep.
That would be my first choice, my wife's Camry is R-12 and will stay that way until it's no longer available.
Really?
Or did you mean Freeze 12?
R12, and my deciding factor is this: Freeze 12 is mostly R134a anyway which is a smaller particle than R12. That would lead towards it leaking out of an old system quicker. I thought I might have some luck and simply be able to throw in a can of R12 or two and walk away from the deal. Yes the Freeze 12 and 134 are bothe cheaper per can but I'm then spending the same money on the conversions. Another reason is it's hot here, real hot. I lived in NY, Alabama, and Atlanta GA and the humidity is killer. But it's in no way the middle of the Sonoran Desert. 118 degrees is 118 degrees. Add to that the wonderful (worst) design of having 2 cats under my feet at all times and the final decision becomes clearer.
Good for you!!
"Do it the right way, the first time."
